g4m8l3r Posted February 21, 2013 Author Posted February 21, 2013 Panel in scb mode? Got a b in electronics and cdt gcse for my ultrasonic wirefree disabled alarm, a joint project shared between the two sorry scb mode? what is that exactly?, sorry this is the first and only alarm iv ever fitted so very limited knowledge on these.
james.wilson Posted February 21, 2013 Posted February 21, 2013 dont worry mate another discussion going on i think. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
g4m8l3r Posted February 21, 2013 Author Posted February 21, 2013 dont worry mate another discussion going on i think. oh right sorry , i think its time I gave up and got some rest lol
Oxo Posted February 21, 2013 Posted February 21, 2013 404 on the link But yes , could be SCB. Time for sleep. Come back tomorr...............ahh it is. Later, much later.
sjsturner Posted February 21, 2013 Posted February 21, 2013 Far left connections 12v and 0v. Not aux in the middle. You need a link of wire between 0v and bell tamp return too. This is also on the far left of the pcb.
g4m8l3r Posted February 21, 2013 Author Posted February 21, 2013 Far left connections 12v and 0v. Not aux in the middle. You need a link of wire between 0v and bell tamp return too. This is also on the far left of the pcb. I have a link between 0v and tamp and still no joy
matthew.brough Posted February 21, 2013 Posted February 21, 2013 sorry scb mode? what is that exactly?, sorry this is the first and only alarm iv ever fitted so very limited knowledge on these. Sirens have 2 methods of getting the power to drive them. SAB draws the power from the control panel and SCB used the sirens internal battery. Are the sirens you connecting proper sirens with a housing and a tamper etc or are they just 12v sirens with just 2 wires coming out of them? www.securitywarehouse.co.uk/catalog/
g4m8l3r Posted February 21, 2013 Author Posted February 21, 2013 Sirens have 2 methods of getting the power to drive them. SAB draws the power from the control panel and SCB used the sirens internal battery. Are the sirens you connecting proper sirens with a housing and a tamper etc or are they just 12v sirens with just 2 wires coming out of them? ok and I have no idea how to switch between these methods, the sirens are just basic 12v ones with a +/- coming out of them.
g4m8l3r Posted February 21, 2013 Author Posted February 21, 2013 Sirens have 2 methods of getting the power to drive them. SAB draws the power from the control panel and SCB used the sirens internal battery. Are the sirens you connecting proper sirens with a housing and a tamper etc or are they just 12v sirens with just 2 wires coming out of them? if i connect it to the hard +/- of the panel then the siren is at full volume
matthew.brough Posted February 21, 2013 Posted February 21, 2013 Ok. You have neither SAB or SCB in that case. You just have a 12v siren. Alarms normally switch the negative to the siren, not the positive so this should be a simple case of connecting the red wire to the +12v supply of the panel and wiring the black wire to the bell trigger terminal and that it, there are no other connections to do. if i connect it to the hard +/- of the panel then the siren is at full volume That makes sense. Try just connecting 1 of the sirens to start with and see if that works as you would expect. If so connect the second and re-test. www.securitywarehouse.co.uk/catalog/
