Alarm Fault On A Veritas R8 Plus
marcus19811981
Its the supply spur. On a 6A MCB they had already provided but had the old Red & black T & E  some one rewired the house in blue brown but left this spur. If they would allow me but won't. I would prefer to run a lead to the panel and plug it in a socket for 24 hours if it cures the problem they will have to get the spur sorted. I can't even be sure it was rewired by a part P electrician as they have no paper for the installation.
I agree. If they 've had the house rewired a few weeks ago, the alarm should have had its own MCB anyway. But they used this existing one and connected directlty to the MCB for the lighting ciruit.
so the whole house has been rewired and they left the spur to alarm in the original cable..have you not asked why..
You have two issues. Well more, but.
1, You have not fully tested all cables. Including the mains feed.
2, Have not established there is a mains fault.
I know these people they want every thing on the cheap.
what happens when you discon and link out all the detection and leave it with just a powered up panel,whats the mains readings..l-n/l-e/n-e
What I intend to do:
1. Install my own fused spur unit and connect it to its own fuse on the consumer unit.
2. Remove all alarm cabling from the panel and link out the zones.
3. Reconnect 1 and 2 above seperatly. I will then know if its the mains supply spur or the alarm cabling.
The problem was I wanted to do this but the customer decided they wanted the system removing and their money back but won't allow me to have the chance to find the problem.
Rewired and no paperwork. And you're insistent on adding a spur of your own?
All the time you spend on this mess is costing you money.
Time to walk away... And perhaps inform the local BCO of your
concerns
