Guest b21playa Posted August 26, 2004 Posted August 26, 2004 this one is for a mate of mine just moved into house and te longe has two sensors as sonas the sensor picks you up, the alarm goes off, not giving the entry delay the zones are set to entry/exit and to 15seconds but still goes off. the dor contact in the same room is set the same and that works any idea what could be the fault and how it could be sorted
Guest linea Posted August 26, 2004 Posted August 26, 2004 this one is for a mate of minejust moved into house and te longe has two sensors as sonas the sensor picks you up, the alarm goes off, not giving the entry delay the zones are set to entry/exit and to 15seconds but still goes off. the dor contact in the same room is set the same and that works any idea what could be the fault and how it could be sorted 21708[/snapback] need more info about room description
Guest Posted August 26, 2004 Posted August 26, 2004 cream walls,brown chairs......the panel type would be more help
Guest b21playa Posted August 26, 2004 Posted August 26, 2004 is a veitas r8 panel and using reflex pir's room is 30ft x 12ft front door is left hand corner with sensor above it pointing to centre of lounge. stairs in middle of room, so both sensors point to bottom of stairs. will try and draw up a pic
Guest b21playa Posted August 26, 2004 Posted August 26, 2004 arrow points to botom of stairs click for picture if knowone can see pic, email me and i will email u the pic
Brian c Posted August 26, 2004 Posted August 26, 2004 are you sure all 3 zones are prog'd as entry/exit? are you sure the front door contact is working? If you don't know......ask.
Guest b21playa Posted August 26, 2004 Posted August 26, 2004 are you sure all 3 zones are prog'd as entry/exit?are you sure the front door contact is working? 21732[/snapback] yes all are entry/exit door contact is working, gives delay beep when door is opened, but the pir as soon as it picks a person up sounds the alarm
Service Engineer Posted August 26, 2004 Posted August 26, 2004 Perhaps the zones are wired incorrectly, like the tamper wired through the zone, or possibly they just arent correct with the zone spec (like zone 3 is actually on zone 5). ........................................................ Dave Partridge (Romec Service Engineer)
Brian c Posted August 26, 2004 Posted August 26, 2004 try programming the pir's as inhibited entry, although if you're sure about the programming and you're sure the detectors are wired to the zones you think they are, it shouldn't need to be that way. If you don't know......ask.
Brian c Posted August 26, 2004 Posted August 26, 2004 also try reprogramming the entry/ exit time as it may not have accepted the '5' last time it was done? If you don't know......ask.
