help
Guest b21playa
Guest b21playa
that will add zone 3 to the inhibited entry suite as well as zone 2
21948[/snapback]
so how can i set the alarm via part button??
when i enter code and press part it only gives restricted zones
Guest b21playa
21948[/snapback]
2 again
we'll come to that shortly...
command 12 please....
sorry, misunderstood the reply (it is quite late) :)
does 13 also give 2?
Guest b21playa
no worries
im just glad that im getting help
Guest b21playa
21957[/snapback]
CORRECT
then the panel is now correctly programmed for full set to have both zones 2 and 3 on inhibited entry.
no reason why that shouldn't work correctly now, but do check that when you re-enter that you hear the entry timer start for a second or two before you fully open the door
I have had instances of very sensitive detectors picking up the draughts around the door before the contact has triggered causing entry faults simlar to the one your suffering from.
Guest b21playa
21961[/snapback]
can i use full set now and it shud be ok?
