Guest b21playa Posted August 26, 2004 Posted August 26, 2004 try programming the pir's as inhibited entry, although if you're sure about the programming and you're sure the detectors are wired to the zones you think they are, it shouldn't need to be that way. 21740[/snapback] do u know how to do it what key presses ive checked each sensor and seen what zone they are on dont know about if they are wired correct
Brian c Posted August 26, 2004 Posted August 26, 2004 enter eng mode press 33 (full set entry tim) press 15 (seconds) press PROG exit eng mode If you don't know......ask.
Guest Posted August 26, 2004 Posted August 26, 2004 the pir maybe picking up door before panel see's door open......seen this before..try blanking the pir and then see what happens...
Brian c Posted August 26, 2004 Posted August 26, 2004 wouldn't matter if all 3 zones are entry/exit If you don't know......ask.
Guest b21playa Posted August 26, 2004 Posted August 26, 2004 the pir maybe picking up door before panel see's door open......seen this before..try blanking the pir and then see what happens... 21750[/snapback] i dont understand how that has anything to do with it. sorry if it sounds rude, but im not trying to be rude the whole point is i dont get delay from sensor as soon as i open the door the delay kicks in but the sensor picks me up and alarm goes off. correct me if im wrong
Brian c Posted August 26, 2004 Posted August 26, 2004 wouldn't matter if all 3 zones are entry/exit 21751[/snapback] If you don't know......ask.
Guest Posted August 26, 2004 Posted August 26, 2004 wouldn't matter if all 3 zones are entry/exit 21751[/snapback] 21759[/snapback] clever s****... it is late tho
Brian c Posted August 26, 2004 Posted August 26, 2004 down there for dancin' If you don't know......ask.
Guest Posted August 26, 2004 Posted August 26, 2004 down there for dancin' 21764[/snapback] careful bri..dancin at your age............stick to the waltz .. mc sinatra on the mic
