FASTCAR Posted August 27, 2004 Posted August 27, 2004 Are you using FULL set program or Part set, as some functions change when Part Set is selected. B)
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 Are you using FULL set program or Part set, as some functions change when Part Set is selected. B) 21800[/snapback] it happens on both full and part ive tried resetting everything
Brian c Posted August 27, 2004 Posted August 27, 2004 you mean you reprogrammed entry time? If you don't know......ask.
Guest RICHL Posted August 27, 2004 Posted August 27, 2004 Its got to be either a panel fault or human error this one - and its more likely to be human error. Check each device is wired to the correct zone by blanking off PIRs andwalk tested them one at a time. If not that the clear NVM and re-prog.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 Its got to be either a panel fault or human error this one - and its more likely to be human error.Check each device is wired to the correct zone by blanking off PIRs andwalk tested them one at a time. If not that the clear NVM and re-prog. 21857[/snapback] each zone is correctly wired cuz ive tried the walk test zone 1,2 and 3 are set to entrey/exit and all others guard. zone 1 - door contact zone 2 - lounge zone 3 - lounge zone 4 - kitchen zone 5 - garden door zone 6 - bedroom 1 zone 7 - bedroom 2 it did the same when the alarm was reset to factory settings could it be wiring fault??
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 you mean you reprogrammed entry time? 21832[/snapback] was originally 30secs, changed to 15secs last night
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 Id also check the door contact is actually working too.What zone is displayed when the alarm activates? Pete 21858[/snapback] what do u mean? please elaborate
bellman Posted August 27, 2004 Posted August 27, 2004 When you enter and the alarm goes off in full alarm, you silence it with your code, what zone light is flashing? Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 When you enter and the alarm goes off in full alarm, you silence it with your code, what zone light is flashing?Regards Bellman 21880[/snapback] zone 2 zone 1 is lit as well but not flashing
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 im in birmingham if anyone could pop drop for a quick free look
