help
Guest b21playa
and zone 2 or 3 light was on when reset?
how are you arming the panel, i just want to check what set state you are using
exact keypresses please.
Regards
Bellman
Guest b21playa
Regards
Bellman
21898[/snapback]
type in code
press full
when reset zone 2 light was flashng
that's bizarre.
the panel is indicating z2 caused the alarm but we have verified that zone 2 is set to inhibited entry
can you answer yes to the following questions:
if you arm the system and go outside the protected area the system sets correctly.
if you then open the door just enough to trip the door contact the exit timer begins as normal and continues for the duration of the entry time?
Regards
Bellman
Guest b21playa
that's bizarre.
Regards
Bellman
21901[/snapback]
yes and yes but when the sensor piks me up the alarm goes off
how can the sensor pick you up if you are stood outside the protected area, i.e. on the other side of the door to the sensor?
Guest b21playa
21903[/snapback]
u asked if i go outside the protected area does it set prpoerly
check previous posts
was in relation to question 2, i need to establish that the timing system functions correctly, so, arm system, goo out thru door, let system set.
when system has set open door a few inches, just enough to trip door contact, if entry timer starts correctly and then lasts for the duration of the programmed time before alarm, thien this verifies that both the door contact has the correct zone programming and that nothing else is affecting the entry time.
Regards
Bellman
Guest b21playa
Regards
Bellman
21905[/snapback]
just tried it and i get 15 secs entry time then the alarm went off
great stuff..
so, we know the following,
1, the exit entry works correctly
2, we have verified that the zone is programmed as inhibited entry.
3, we have verified zone 2 in the lounge as being the zone causing the alarm.
hmm, 2 mins while i have a quick scan of the manuals..
regards
Bellman
