Guest b21playa Posted August 27, 2004 Posted August 27, 2004 zone 2 and 3 cause alarm all depends where i stand in lounge and which one picks me up both of these are set to inhibited at the moment
bellman Posted August 27, 2004 Posted August 27, 2004 right, both versions of the panel have the same programming commands for the changes we've made. only thing i can suggest is you change the part set zone types to match the full set ones and try again. to do this go into engineers and type 216 prog, 222 prog then 232 prog the panel will "chime" to confirm the changes reset twice to exit. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 right, both versions of the panel have the same programming commands for the changes we've made.only thing i can suggest is you change the part set zone types to match the full set ones and try again. to do this go into engineers and type 216 prog, 222 progĀ then 232 progĀ the panel will "chime" to confirm the changes reset twice to exit. Regards Bellman 21913[/snapback] ive done that but what do i try again???? still instant alarm on zone 2 and 3
bellman Posted August 27, 2004 Posted August 27, 2004 code then part. go outside via door, let system set. open door enough to trigger timer and exit entry tone see if system trips then when you attenpt to disarm it. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted August 27, 2004 Posted August 27, 2004 if it still plays up after this, the next step is swapping zones as service engineer suggested earlier... Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 code then part.go outside via door, let system set. open door enough to trigger timer and exit entry tone see if system trips then when you attenpt to disarm it. Regards Bellman 21915[/snapback] i part set the system and went outside wen it set i came nside and the entry exit delay started, the sensor picked me up and the delay carried on does that help??
bellman Posted August 27, 2004 Posted August 27, 2004 so you were able to successfully disarm it without it going into full alarm, correct? Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 so you were able to successfully disarm it without it going into full alarm, correct? 21918[/snapback] what do u mean full alarm??? if u mean without the siren going off, then yes
bellman Posted August 27, 2004 Posted August 27, 2004 great stuff, that would suggest that the panel is not accepting the programming change made to zones 2 and 3. right, what we'll do is verify a few other things, firstly what version of the panel you have and secondly that the panel is correctly accepting the command entered. Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 great stuff, that would suggest that the panel is not accepting the programming change made to zones 2 and 3.right, what we'll do is verify a few other things, firstly what version of the panel you have and secondly that the panel is correctly accepting the command entered. 21920[/snapback] how do i do that?? all i know is that it is a veritas R8
