black knight Posted August 27, 2004 Posted August 27, 2004 sorry to butt in to the conversation but have you double checked what zones 2 and 3 are programmed as in full set go into engineer mode press 1 2 number 2 should be lit if it isnt press 2 then prog press 1 3 number 2 should be lit if it isnt press 2 then prog exit eng and try again obviously as in previous posts to check part set it is 2 2 number 2 should be lit if it isnt press 2 then prog 2 3 number 2 should be lit if it isnt press 2 then prog depending on where you set from for night set - if you are going to be walking thro 2 and 3 1st to get to keypad then 2 2 press 6 prog 2 3 press 6 prog paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
bellman Posted August 27, 2004 Posted August 27, 2004 right, go into engineers and type 55 prog, do you get the chime or the low error tone? Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted August 27, 2004 Posted August 27, 2004 sorry to butt in to the conversation but have you double checked what zones 2 and 3 are programmed as in full set go into engineer mode press 1 2 number 2 should be lit if it isnt press 2 then prog press 1 3 number 2 should be lit if it isnt press 2 then prog exit eng and try again obviously as in previous posts to check part set it is 2 2 number 2 should be lit if it isnt press 2 then prog 2 3 number 2 should be lit if it isnt press 2 then prog depending on where you set from for night set - if you are going to be walking thro 2 and 3 1st to get to keypad then 2 2 press 6 prog 2 3 press 6 prog paul 21922[/snapback] Yup, already done that... Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 sorry to butt in to the conversation but have you double checked what zones 2 and 3 are programmed as in full set go into engineer mode press 1 2 number 2 should be lit if it isnt press 2 then prog press 1 3 number 2 should be lit if it isnt press 2 then prog exit eng and try again obviously as in previous posts to check part set it is 2 2 number 2 should be lit if it isnt press 2 then prog 2 3 number 2 should be lit if it isnt press 2 then prog depending on where you set from for night set - if you are going to be walking thro 2 and 3 1st to get to keypad then 2 2 press 6 prog 2 3 press 6 prog paul 21922[/snapback] zone 2 and 3 are set to 2 as you said for night alarm is set via RKP upstairs
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 right, go into engineers and type 55 prog, do you get the chime or the low error tone? 21923[/snapback] CHIME
bellman Posted August 27, 2004 Posted August 27, 2004 you have the newer version of the panel then mate, that function programs the chime suite, the older version dosnt have this function and you get the error note there is no logical reason why the panel would exhibit this behaviour when only full set since it works correctly on part set when set to the same settings as full set. i don't think zone swapping would help either as it's happening on zones 2 and 3. regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest b21playa Posted August 27, 2004 Posted August 27, 2004 you have the newer version of the panel then mate, that function programs the chime suite, the older version dosnt have this function and you get the error notethere is no logical reason why the panel would exhibit this behaviour when only full set since it works correctly on part set when set to the same settings as full set. i don't think zone swapping would help either as it's happening on zones 2 and 3. regards Bellman 21927[/snapback] do u have any other ideas???
black knight Posted August 27, 2004 Posted August 27, 2004 i would suggest a radical move perform the "return to factory setting" procedure and then completely reprogram again. to do that go into eng press 07(All leds will go out) then prog. system will chime and then revert to prog mode and leds will reilluminate paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
bellman Posted August 27, 2004 Posted August 27, 2004 since it works correctly in part set, use the part set as the full set.... Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted August 27, 2004 Posted August 27, 2004 i would suggest a radical moveperform the "return to factory setting" procedure and then completely reprogram again. to do that go into eng press 07(All leds will go out) then prog. system will chime and then revert to prog mode and leds will reilluminate paul 21929[/snapback] Have you not already done this b21playa? if not, do so... Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
