Concept Alarm
Brasilia
Hi. We have just moved house, and have a Concept alarm fitted. I need to remove PIR sensor to decorate, but manual does not tell you how to. I assume they have tamper switches. How do I isolate it, without setting alarm off?
Without the engineers code ( which we cannot provide here) you can't isolate it.
It depends how the systems been setup the tamper may not be active
Just remove the lid , put your code in to stop the noise and refit and reset once your done.
Cannot see it having engineer reset tbh
Be aware that in taking the PIR down you may blow fuses, which could cause the outside sounder (if fitted) to sound and you may not be able to stop it. It may or may not cut off after 20 mins.
If you are not confident then:
1 - don't try it at 9 o'clock at night
2 - get a firm in.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
