Scantronic 9751
whizzer
tried to check the charging voltage today and found nothing on the battrey leads ?
is this a "trickle" charge or a common fault ?
battrey tested ok.
If its detecting battery presence some panels remove charge voltage when battery disconnected as nothing to charge.
The old days of 'trickle' charge are going as most new panels dont work like this as they have to charge the battery harder to hit the recharge time on the bigger batts.
I suppose this could be an old panel and the above be wrong
how would i take the charging voltage reading if thats the case and the voltage is removed when i diss the battrey ?
As above some of the newer 9751's won't charge if it doesn't see a battery.
Load test the battery and get its voltage .
Collect to panel and measure across output it should be higher.
