frankh1949 Posted March 24, 2013 Share Posted March 24, 2013 Hi guys, my name is Frank and I'm a semi retired IT guy who also got involved with CCTV as part of the package. I moved from Bedfordshire 2 yrs ago to West Wales to get away from the yobs, vandals etc.. there are some cracking looking sheep here and I bought a new pair of wellies !! Anyway.. although crime is not a problem here I want to put some cameras up to keep an eye on the dogs as my yard and garden is to the side of the property so its difficult to keep an eye on. I have 4 cheap cameras left over from past jobs and a Xvision tdvr 8 with a failed HDD so I opened the DVR and confirmed the Master HDD was knackered and tried to play events from the Secondary drive which would not play....I had already reset the box to factory defaults. I plugged a camera in to prove that the rest of the box worked and could see the image behind the list of events. I was unable to return from the list to the menu as the system froze. I powered down the box but now cannot boot the system as it hangs on "System initialize" I found a switch inside the box which just reboots but does not get past the problem. I've removed the battery,pushed the internal switch for 60 seconds and left battery out for 10 minutes all to no avail. I've disconnected all drive cables, ribbon and power but cant get past initialisation. Any ideas/ suggestions, other then the bin? Thanks Frank Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/ Share on other sites More sharing options...
MrHappy Posted March 24, 2013 Share Posted March 24, 2013 does it start w/o the HDD fitted ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310460 Share on other sites More sharing options...
james.wilson Posted March 24, 2013 Share Posted March 24, 2013 Have you tried replacing the drive? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310461 Share on other sites More sharing options...
frankh1949 Posted March 24, 2013 Author Share Posted March 24, 2013 With both drives fitted, (1 failed 1 good) it used to boot ok but no events could be accessed, when I disconnected the failed master drive it booted and displayed the list of events on the secondary drive. Since then it will not boot with drives in or out.. Is it possible that the saved boot up data is corrupted? Does leaving the backup battery for 10 mins usually reset to defaults? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310462 Share on other sites More sharing options...
james.wilson Posted March 24, 2013 Share Posted March 24, 2013 How would defaulting it help. You may be able to image the drive and then replace them securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310492 Share on other sites More sharing options...
frankh1949 Posted March 25, 2013 Author Share Posted March 25, 2013 Thanks for the responses guys. My logic is this: Even with new unformatted drives fitted the box should boot to allow you to access the menus to format the drives. Prior to the box not getting past the initialize stage, the system would boot as follows: With the faulty primary drive and good secondary and cd connected it would boot and detect the cd but no drives and would give access to all menus With the primary drive disconnected it would boot and detect the cd and secondary drive and show files on the secondary drive. With all drives disconnected it would still boot ok After resetting to factory defaults via menu it booted. So to get through the boot sequence it doesnt need drives fitted... it will just check and report none detected. I know it doesnt need cameras fitted to boot so what else is it checking for??? hence my thoughts re setting defaults in case its set to look for something that doesnt exist. It has not booted since connecting a camera to test when the box was powered up, the camera is good and works fine. I know if you go by the book you really shouldnt plug a camera in when box is powered up but I've never killed any equipment doing so. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310501 Share on other sites More sharing options...
james.wilson Posted March 25, 2013 Share Posted March 25, 2013 I wouldn't expect it to kill it either securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310504 Share on other sites More sharing options...
Lwillis Posted March 25, 2013 Share Posted March 25, 2013 I've never seen one be killed by unplugging a camera . Have seen them not hoot up if it detects a faulty drive and it will try and read info from it and can get stuck if it finds a dodgy sector . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310579 Share on other sites More sharing options...
sjsturner Posted March 26, 2013 Share Posted March 26, 2013 I've never seen one be killed by unplugging a camera . Have seen them not hoot up if it detects a faulty drive and it will try and read info from it and can get stuck if it finds a dodgy sector . Its not an owl dude! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310696 Share on other sites More sharing options...
Lwillis Posted March 26, 2013 Share Posted March 26, 2013 Twit twoo! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34255-hi-guys-i-need-some-advice/#findComment-310719 Share on other sites More sharing options...
