Ats On Eng Reset
MrHappy
Grade 3 only
thought you meant the panel...  had to do an eng reset on on ATS recently - should be known as a rocket scientist reset!
You recovered from the trauma of having to do an ATS?
it's wasn't that bad (last time i touched an ATS was a TX Maxx and was 6 years ago!)  but it certainly isn't straight forward!
The end user loves you to bits. They asked about the dreaded chime. It's only just been put into the latest software but without installing buzzers it's a waste of time as the RAS volume is so small.
can you do a link to the int siren?
Bit loud? Yes it is called macros. You would create an event flag called chime, put it in all the zones you want to chime, set a macro so when chime event flag went active to pulse the event flag of the siren for 1 second.
1 second isn't that long really, it prob takes half a second to actually get started and then dies off straight away.  might be perfect.  last last one was feckin loud anyway.
