Driller Posted March 31, 2013 Posted March 31, 2013 As suggested here by Oxo, http://www.thesecurityinstaller.co.uk/community/topic/34167-g2-siren-current-draw-again/page-2 and after all the kind help (albeit with a certain degree of piss taking ) you guys have given me over the years, this thread is an opportunity to give something back. So, any questions about teeth in general, including implants, fire away Quote
Driller Posted March 31, 2013 Author Posted March 31, 2013 Can't see how to transfer quotes so, Oxo said: So Driller, what else is needed. Just applied for a freebie new Colgate toothpaste on the market (Check FB) but generally use Sensodyne and Oral B toothpastes alternating. As one is for whitening and the other for general good hygiene. Change the Oral B lekky brush head every 3 months. Have to admit oral hygiene was poor in the past especially with smoking ( Stopped 10 yrs ago). Any suggestions for more years with all the nashers with a reasonable "white" finish. (Thinking about a "bleaching"), but will the crown not be affected? ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Actually for cleaning the type/make etc of toothpaste doesn't make any difference as most of the cleaning effect is from the brush, the toothpaste is there just to help things along a bit. If you've got sensitive choppers though Sensodyne is very good. Oral-B electric brush is very good and good value at £15 or £20, no need for a £100+ gadget. I'm all for whitening although prices vary (!), crown won't be affected at all so in fact you have to be careful depending where it is to avoid looking like a zebra crossing! Quote
sjsturner Posted March 31, 2013 Posted March 31, 2013 Ok i had root canal 2 years ago and occasionally get some pain in that area usually after eating chocolate is it likely the root canal needs re doing? Btw rct hurt like feck and no pain relief! Quote
Driller Posted March 31, 2013 Author Posted March 31, 2013 (edited) sjsTurner said: didnt know we had our own dentist on here! i had root canal about two years ago and occasionally get pain in the same place normally after eating chocolate and other rubbish,is that normal? he didnt even numb it when doing the rct it hurt like a biatch especially afterwards for about 5 hours! ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- If you're getting pain when eating chocolate this suggests a nerve involved on a decayed or sensitive tooth so maybe the next tooth along which is not root treated? Otherwise if the pain is happening when you bite down on a hard bit a chocolate this would suggest the root treatment has failed. Do cold things hurt the tooth in question? ETA which tooth was root treated BTW? ETA2 Beat you to it, I transfered your post from the other thread Edited March 31, 2013 by Driller Quote
sjsturner Posted March 31, 2013 Posted March 31, 2013 Cold stuff no. In fact cold water calms it down Quote
sjsturner Posted March 31, 2013 Posted March 31, 2013 (edited) Top 6 teeth to the right. One of those double ones! Bet i sound like a right tard lol! It is rarley bad pain now but seems to happen with chocolate and fast food ect ( all the bad stuff ) Edited March 31, 2013 by sjsturner Quote
Driller Posted March 31, 2013 Author Posted March 31, 2013 (edited) Cold stuff no. In fact cold water calms it down Top 6 teeth to the right. One of those double ones! Bet i sound like a right tard lol! It is rarley bad pain now but seems to happen with chocolate and fast food ect ( all the bad stuff ) Well usually if cold calms a tooth pain this suggests infection which suggests the RCT (root canal therapy) has failed. At this point I need to state the caveat that I can't guarantee anything a 100% I write on here as I only have descriptions to go by! The 6 tooth is a molar with three roots and normally 3 canals. Sometimes however the ones at the top can have 4 canals which can catch a dentist out from time to time. I've root treated this tooth before now and had to go back in later to find and fill the hidden 4th canal after the patient complains of discomfort. Try tapping (gently!) on the tooth with the end of a knife handle. If it's more sensitive to this than those around then this tooth is probably the problem. ETA cause the bloody number lock was off! Edited March 31, 2013 by Driller Quote
MrHappy Posted March 31, 2013 Posted March 31, 2013 this thread is an opportunity to give something back.Nice one, Quote Mr Veritas God
Oxo Posted March 31, 2013 Posted March 31, 2013 Thanks Driller. The Oral B was £40 in Boots down from £100 But a good thing in my book. Glad you agree, as I thought the crown will not be affected by the bleaching so if I went that route would be a minefield as it is the Central Incisor ( looked that up lol). To be fair teeth are straight and although not brilliant white not too bad. The filling that was changed, has fallen out again. So not going back to that silly cow again. Doubt another will do it for free. As no pain leaving it for a bit until less busy and can get the time to do it. Might have the fooker pulled instead if it looks like it will fall out again. A crown is just toooooo fookin expensive! Way to go for doing the thread though, hope some get use from it. Quote
sjsturner Posted March 31, 2013 Posted March 31, 2013 Well usually if cold calms a tooth pain this suggests infection which suggests the RCT (root canal therapy) has failed. At this point I need to state the caveat that I can't guarantee anything a 100% I write on here as I only have descriptions to go by! The 6 tooth is a molar with three roots and normally 3 canals. Sometimes however the ones at the top can have 4 canals which can catch a dentist out from time to time. I've root treated this tooth before now and had to go back in later to find and fill the hidden 4th canal after the patient complains of discomfort. Try tapping (gently!) on the tooth with the end of a knife handle. If it's more sensitive to this than those around then this tooth is probably the problem. ETA cause the bloody number lock was off! dude! Il see how long i can bear it. Only got it done originally because couldent sleep for 2 days and was on my knees with pain Quote
