Chubb Delta 5
ryan042000
Yes i thought so to but the siren just starts up when power is applied to terminal 2&3 and the tamper switch is closed a red and green led energise when thamper switch is closed bit confused im used to adt bells
Yeh if i can figure out the hold off and the sab im sorted got the tamper sorted byt im not sure if theres somthing wring with the sab do you know if this needs a pos trig or neg
Judging from what i can gather you need
Terms
1= 0v
2= 12v
3= 0v
4= bell trig
5+6 you know what to do with that!
7= 0v
8= tmp return
9= 12v
10= strobe
You can put 0v in term 3 and link terms 3 and 1 and 7 together in bell box
Also put 12v pos in term 2 and link 2 and 9 together
Then your bell trig goes in term 4
Your tmpr return in 8
Strobe trig in 10
