Chubb Delta 5
ryan042000
If I remember correctly the delta bells are a +ve trigg. Unless there's a jump link on them to change that.
Ive never even seen one so im not sure but if thats the case then hes applying a neg currently so the trig isnt there.
He says it powers up ringing i reckon he has 12v in term 1 instead of 0v
If the trig is + i take it hel have to use a relay?
Not installed a prem or is there prog +12v output?
Yeh the prems can switch from pos trig to neg ( sab/ scb mode)
Ill try your sugestions and get back to you tomorrow hopefully it works
Dont hold your breath! I havent personally installed either but thats how i would wire it. Going off what you have shown me, good luck
I'll have a proper look in the morning but found this online .
Fairly straight forward;
fault (not used)
fault (not used)
tamp (0v)
tamp (tamp back to panel) - Tamper return
0v (ov) - Neg hold
12+ (12v) - + hold
eng (not used)
rtest (not used)
str (- strobe trigger) - self explanatory
hoff (- Bell trigger) - bell neg
bt- (Battery -) Batt
bt+ (Battery +) - Batt
PZ1 not sure about these as someone has taken them off - PZ will stand for Piezo
PZ2 - ditto.
fault (not used)
fault (not used)
tamp (0v)
0v (ov) - Neg hold
12+ (12v) - + hold
eng (not used)
rtest (not used)
PZ2 - ditto.
Delta 6?
