Bell Boxes & Sab Batteries
adrian41uk
We all know that the gel batteries in an alarm panel should be replaced at regular intervals but what about the battery packs in SABs?
I know that these are usually a different battery technology (usually NiCAD or NiMH) as opposed to the lead acid types used for panel backup and are usually soldered in but they must have a servicable life?
Does anybody routinely replace the module/entire bell box after a certain number of years or are they just left to die?
No routine replacement but tested every service visit.
Same here. No routine replacement but tested on a site Maintence visit.
How long would you guys say a bell should last/be replaced , I'd say around 10 years
Thanks for the replies, Guys.
Tested as in remove the hold-off voltage & let it sound for the full 15min? Or just quickly remove hold-off & let it sound for a few seconds?
Or just Bell test from the panel (which doesn't actually use the SAB battery....)
I remember a spate of oddy 3e with faulty backup batterys.
We test every maintenence dont always let it go full duration tho, depends on age/ location ect
Same ones for em iirc, can't say I know anyone who has one.
