Scantronic's Dual Signalling
Guest paulbenson
Guest paulbenson
Hi, help required! Just found while tiding up a Scantronic Dual Path signalling panel. C/W power supply unit antenna etc. I have just looked on Scantronics web site for for information but cannot find anything listed. I have the install manual but all it says if BT Red care / GSM but no information on the unit itself. If anyone knows anything about them can you please let me know.
Regards
Paul
its not a csl dualcom isit?? white unit with green writing on...
Guest paulbenson
22095[/snapback]
Hi, dont think so. Just in a white metal box with 3 screws, no visable writing on the out side.
Paul
Sounds like a Scantranic GID - Old type redcare GSM unit
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Guest paulbenson
22102[/snapback]
Thanks Buster, are these any use anymore?
Paul
They are site specific and can only be used on the site is was registered for
Guest paulbenson
22111[/snapback]
Thanks Buster for your help, will just make use of the PSU then
Paul
Its Def a GID1, and as previously stated its site specific, thank god versus came out with a normal redcare sized one!!
