The Ups And Downs And Ins And Out Of Spread Spectrum
I've had a couple of threats of legal action.  In themselves baseless but it means they want to go down that route...
I have a blog, some of which is about alarm security and reverse engineering:
http://cybergibbons.com/
  • Replies 50
  • Views 6.6k
  • Created
  • Last Reply
The posts on rolling code and encryption are up now as well, if anyone wants to take a look.
ill be “disarm the system 937459384322″ and so on.
The sequence of this codes is essentially random to an observer, and the code is long enough that it makes guessing the next one very difficult.
Unlike spread spectrum, this sequence is generally extremely long in small systems.
Keeloq is a proprietary implementation of a rolling code protocol, often used in car keyless entry systems. The rolling code is 32-bit, which essentially means it is impossible for someone to guess the next code.
Keeloq does have weaknesses. The major one is that it is possible to recover the key used to seed the random number generator. Once you have this, it is far easier to guess the next code. It’s still very challenging though.
What issues are there with rolling code?
Again, the devil is in the detail. Rolling code is a sound principal – but it must be implemented correctly.
Predictable codes
The whole thing falls over if someone can guess the sequence of codes you are using. There are a number of ways that this can happen.
If your code is short (say, 8bits), the an attacker has a 1/256 chance of getting the next code correct if he chooses randomly. If your code is long (say, 32 bits), then it is 1/4294967296. Whatever method you are using to guess the codes, you can clearly see that the longer the code, the harder it will be.
A good pseudo-random number generator (PRNG) can be seeded – you give it a key which determines how it will hop. It shouldn’t matter what the algorithm is or if the attacker knows the algorithm, as long as they don’t know the seed, they shouldn’t be able to predict the sequence. Unfortunately, many products either used a fixed seed across all products (this makes protocol design, especially with a one-way radio, much easier) or the algorithm is bad.
How can the algorithm be bad? Say we have a PRNG with this output when seeded with “1″:
7, 3, 4, 1, 3, 6, 1, 3, 2
If I were to seed it with “2″, the output should be completely different:
8, 3, 3, 2, 7, 1, 5, 3, 1
But some systems simply use the seed to skip some of the output i.e. with a seed of “2″:
3, 4, 1, 3, 6, 1, 3, 2, 8
Notice this is just the first sequence shifted along one digit!
If I know the entire sequence, then all I need to do is gather a few packets and I can work out where we are in the sequence. The number of packets I need varies, but with a poor PRNG or short code, it’s not very many!
Worse still, some “rolling code” systems use a code like:
1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Whilst this might protect against casual replay attacks, it is not hard for an attacker to guess the next number.
Limitations with one-way radios
If your keyfob can transmit but not receive, there is a small problem. Each time it transmits, the code rolls forward. There is no guarantee that the receiver will hear the transmission.
This means that the transmitter’s code can be further ahead in the sequence than the receiver. This needs to be taken account of – what happens if you are idly pressing the disarm button in your pocket whilst waiting for the bus?
Most systems deal with this by checking for a valid code over a “window” of acceptable values. This could, say, be the next 256 codes. This has an interesting effect on guessing. If I have a 16 bit code, there are 65,536 possibilities. If the window was only 1 long, I would have a 1/65,536 chance of randomly guessing the code. If the window is 256 long, we reduce this by a factor of 256 – to 1/256. That’s a big difference.
Message substitution
A very simple rolling code implementation just appends the pseudo-random code onto the message i.e. “disarm the system 878463098273″
There is no link between the message (“disarm the system”) and the code (“878463098273″).
This means we can change the message and use the same code, providing that the receiver hasn’t received the code.
How could this be done? I’ll give one possible attack.
When you press “arm the system” on the keyfob, it will actually send more than one packet, to ensure that the receiver gets the message. We have something like:
arm the system 736474747363
arm the system 093219457437
arm the system 384838738383
arm the system 732878476655
If I am in the position to jam the receiver, but still receive the genuine packet, I can do the following:
1. Record all 4 packets.
2. Immediately replay the first two to arm the alarm so the user does not see an issue:
3. Hold onto the last two packets.
4. Change the messages on the second two packets to:
disarm the system 384838738383
disarm the system 732878476655
And bang, we have disarmed the system.
Replay attacks still work
As long as the packet never reaches the receiver, we can still grab a transmission from a keyfob and use it later. This means someone could press the disarm button on your keyfob whilst you are away from the house (say, when you pass your keys to the checkout assistant to scan your loyalty card), and then replay it later.
Conclusion
Rolling code, again, is a good idea, and if implemented well, can protect against a lot of attacks. Many systems do not implement it well though – the above vulnerabilities can be found in real world alarm systems.
A much more robust solution is to use timestamps in the messages and then use encryption and a message authentication code.
If anyone is interested, Atmel have a really good app note on implementing a secure algorithm with one-way radios.
 qoute form gibbons webby
What criteria to people use for picking one alarm over another then? I see a lot of people calling brand X ****, but then from my perspective it is secure.
my choice is based on prior experiences and others recommendations.
price is a consideration, when you can loose a job over £10 but i ere on reliability. no point saving £50 if it causes call backs.
i like longevity which part if is compatibility of older modules with newer control models, so as updates come around due to age it is cheaper for the client, and i need carry less service stock. end user being able to operate it is also high in the list.
i use Gardtec Risco, not saying they are perfect but apart from the earlier years and their EWB's i find them very reliable and extremely robust against electrical storms, mains born interference etc.
with regards of rolling codes, sometimes get issues with radio fobs no longer working, or a battery detector 'lost'. seems to happen more with offices or blocks of small apartment flats. perhaps wiFi or bluetooth having a de-sensing or bleed over effect, knocking the sync out of kilter
most times re-learn the device and its fine.
Edited by arfur mo
Interference can cause the receiver to miss transmissions, certainly. WiFi and Bluetooth are normally pretty clean - they don't really go much outside of the 2.4GHz band they are allocated. It could just be the density of 434/868MHz transmitters in those areas. Cheap video senders are pretty adept at being wide band jammers as well.
i ave also found cheap wireless door bell call buttons can interfere as battery gets low i guess spectrum is less controlled. not so bad if it's on the alarmed house but the worry is what about nearby houses?
Edited by arfur mo
Yes - that could well be a common cause. Cheaper products use something called a SAW resonator to generate on-off keyed AM signals. As the battery drains, and they are not driven as hard as they need to be, they start producing a lot of ****.
