The Arab Posted April 28, 2013 Author Posted April 28, 2013 The output is programmed as 11 in digicom output 8 and is positive but doesn't change status doesn't flicker or drop out and as I said only the 790/900 manual but never saw anything about altering output state Trade Member
Oxo Posted April 28, 2013 Posted April 28, 2013 Config 019 is one way. Try making a custom output on the panel outputs ( 4 of them), if you cannot with all them its fooked.
The Arab Posted April 28, 2013 Author Posted April 28, 2013 Will try again (I had programmed the clean contact output 1 as 2nd alarm but that never changed) and will spend a bit time on your custom output suggestion Trade Member
Oxo Posted April 28, 2013 Posted April 28, 2013 To be fair if none are changing the panel is due for a change as good as they were.
MrHappy Posted April 28, 2013 Posted April 28, 2013 TS700 could do confirmed. did'nt they do something weird like restore the 1st int when sending 2nd int ? Mr Veritas God
james.wilson Posted April 28, 2013 Posted April 28, 2013 Probably not to the relevant version of dd243 if for a urn securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted April 28, 2013 Posted April 28, 2013 did'nt they do something weird like restore the 1st int when sending 2nd int ? I think an issue was the second signal restored after a while but left intruder active. They definitely didn't do Abort hence the abort module. Anyway OP, replace panel. Edit:- Oh that reminded me there's an option for 2nd Alarm time if that's "000" there's your issue. Be in Engineers 1 - 5 somewhere near the end.
The Arab Posted April 28, 2013 Author Posted April 28, 2013 No changed it to 005 set alarm off for 10 minutes and it never changed sorry Trade Member
breff Posted April 28, 2013 Posted April 28, 2013 TS900 did confirmed but had no time window, same as 2500, its the reason we moved away from them. You could have a zone activate today then a 2nd in a weeks time and it would send a confirmed if it hadn't been reset. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Oxo Posted April 28, 2013 Posted April 28, 2013 Bit strange not being reset though over that time period???
