Alarm Protection Posted May 1, 2013 Posted May 1, 2013 Agree with alter. Most cams are made in china now so in this country a wee bit of silicone round the cam is a must. !
arfur mo Posted May 1, 2013 Posted May 1, 2013 IMHO item needed fitting like thisgob up.jpgto prevent that problem i prefer to make a simple bracket from galvanised sheet steel so dome is underneath, i also fit the poly lid off a £0.99 12" ish salad bowl, remove air vent gives a neat hole for cables, to stop rain getting on the lens, and also acts as an excellent gasket.joint boxes all cables enter from below, whats nor holed can't leak, i like those black poly mains junction boxes with the rubber blind grommets and clip on lids so no screws to rust, silicone or plumbers mate to the lid joint, find needs no drain holes. where boxes already in place by previous installer then i drill several 2mm holes, as just 1 or 2 can get blocked. if coming through a wall then joints in dome wall bracket, or housing, or depending in wall type aesthetic needs, i sink boxes with square hole cutter, leaving just the lid 'proud'. i always ensure any are kept a high as possible, don't cut off power plugs as that kill warranty more of a pain to swap out, plus if i need it i can power a test monitor with a 'Y' lead. // waits formoans about long post . If you think education is difficult, try being stupid!!!!
MrHappy Posted May 1, 2013 Posted May 1, 2013 Moans about long post!! Lol I thought it was short & too well spelt to be "iphone arf's" content.... Mr Veritas God
goncall Posted May 1, 2013 Posted May 1, 2013 I thought it was short & too well spelt to be "iphone arf's" content.... to be fair he's just woke up from his afternoon nap..give him a few hours ..
arfur mo Posted May 1, 2013 Posted May 1, 2013 I find dropping one negates the need for silicone. whatever do you eat? If you think education is difficult, try being stupid!!!!
arfur mo Posted May 1, 2013 Posted May 1, 2013 I like a drain hole, 2mm ? for avery tight fit? If you think education is difficult, try being stupid!!!!
Oxo Posted May 1, 2013 Posted May 1, 2013 whatever do you eat? You`re too senile to even see the joke.
