Texecom 48Elite Wireless
Hi can any one help! I've got a texecom 48 with 6 willer less devices and cuts 11/12 are active and can not set system? I've walk tested and all zones activate? But in system tests zone are showing active?! I've tried staring the radio paths again? But zones still active? The problem started after the doors have been open all day?
Can anybody shed any light please !
Thanks
Thanks!!! But checked everything! System walk tests all ok so radio path is ok! Linked out internal read switch again! Unit still showing active when setting? I do like texecom but this new radio mesh units seem very unrelable? Have already on texecoms advice returned 2 units already! System only 2 wks old!!
Did you default the panel before programming it?
Hi thanks for the replies, yes I fully defaulted the panel and other than the two replaced units I have had no problems. Untill yesterday when the shed doors we're open all day? I have tried to push through the radio paths to see if it is signal loss?but the system is not telling me that! It's an annoying problem!! Again hanks for the replies!!
