Gsd Grade 3 Wireless Alarms
A mere 32, unlike my ats friend.
why do you fit a keypad for every group then,your words..
The exact same reason as we do with galaxy. The end user.
how do they know which one to switch off when there all lined up together..
It's rare that there are more than 2 RAS side by side but they have a sticker on them tell them the alarm group it controls. It is expensive but it works well. At adt I remember having multiple keypads on the 4250 so resuming that couldn't handle multiple groups from the same keypad.
Re the multi group thing on a single circuit on a gal. You can only use the * group modifier on final zones not entry zones. So if pts is in use you need 2 contacts, a relay or links.
off topic and i know it was said the contacts were wired in series. So just for info
Just name the groups
That's part of the problem with ats, you disarm areas, not groups.
Didn't know that, thanks for sharing.
