Agreed. If something has a weakness i want to know, then there are 2 options
1 discuss the issue and get a resolution.
2 if 1 doesn't work change product
Absolutely
Really? I would have thought you'd need a lot more data than that.
I suppose if you don't like your panel manufacturers anti-code you can disable it and use the RR input method.
The key would need to be longer than the pin for it to be difficult. With it being so short, it's really not hard.
I have a blog, some of which is about alarm security and reverse engineering:
http://cybergibbons.com/
Your approved vendor/equimpment list may end up quite small then...
Thanks, I guess?
Ha ha. Not in a personal way cg.
+1
I've just updated the blog with my findings from the reverse engineering of Technistore, if anyone is interested.
Interesting, can't say I understand any of it but intend to sit down in darken rm & read though it proper
