Galaxy Flex 20, Strange Error/warning
Hi
I have a flex 20 panel with a strange error. (Not sure what it is).
Panel is bought and installed by me, I don´t have a service contract. I´m using RF units only.
It has been working perfectly until now (or stil is except the error).
My main door with a magnetic contact (DO800M) is programmed as Part-Final zone.
When I set the system (full or part doesn´t matter) the panel displays 1021 Entré (which is my main door)
Whith the choices [esc] to cancel and [enter] to override.
If I override the system sets and everything is fine. I´ve triggered the system via the main door and it works.
Nothing shows up in the log and the magnetic contact seems to work.
Any idéa why I recieve this error (or warning rather...)?
If you enter your code and select Display->Zones->1021   What does the zone information give ?  Press '#' and what info is displayed ?
Display Zone gives me
1021 Closed/Open (woorking fine)
RF105
Sig09
Lo03
Can´t fins anything about it in the logs, displayed as a normal set operation.
The exact info displayd when setting (part or full) is
1021          Part-Final
Esc to cancel, Ent to override
Thank you for the reply
Nothing, I just need to press enter when the message appears and the system sets as usual. (with a user code or by using a keyfob)
I have aloso tried the manager code to set the system and the result is the same: 1021 Part-Final...........
When I exit engineer mode everything looks fine, no tamper warnings or anything like that.
I bit annoying as the keyfob more or less become obsolete because I stil nedd to press a key [ent] to set.
Did a reboot and ended up with a system error message so something must have gone terribly wrong.
Just did a cold start......So back to programming again :xmas:
Thanks for all the help guys!
