ruraldev Posted May 19, 2013 Posted May 19, 2013 Hi I have 2 Texecom Premier 48 alarms in my properties and I wanted to use the same tag with both systems. I tried it but when I add the tag to the second system it doesn't work on the first system. I thought that the tag would give out an ID which would be accepted by the system if programmed, but it seems that the tag is written by the system. Any ideas? or will I need 2 tags? Thanks in advance Gordon
PeterJames Posted May 19, 2013 Posted May 19, 2013 You need to import the tags Thats interesting, can that be done on Texe Andrew?
Cubit Posted May 19, 2013 Posted May 19, 2013 Thats interesting, can that be done on Texe Andrew? Yes. The issue came up a couple of years ago regarding using the same token on different kit/sites. Seems there's two ways to enrol a fob. The Texe boys will have the correct terminology but in essence, when enrolling. If you add new fob, it writes a new code to the fob, if you import, it adds the fob number to the panel whilst leaving the fob alone.
AdrianMealing Posted May 19, 2013 Posted May 19, 2013 Yes. The issue came up a couple of years ago regarding using the same token on different kit/sites. Seems there's two ways to enrol a fob. The Texe boys will have the correct terminology but in essence, when enrolling. If you add new fob, it writes a new code to the fob, if you import, it adds the fob number to the panel whilst leaving the fob alone. Correct, use the Import option amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
Oxo Posted May 19, 2013 Posted May 19, 2013 This has been covered here before. Catches many out with the import/export setting.
PeterJames Posted May 19, 2013 Posted May 19, 2013 This has been covered here before. Catches many out with the import/export setting. I try to read every topic but if I see other mods participating I sometimes dont bother
arfur mo Posted May 19, 2013 Posted May 19, 2013 seems peculiar, i'm curious what advantage it serves (over straight enrolment to both panels) other than having users in the same user slot on each? then if its lost admin has to also know about using this option. while in fobs, anyone else allocate tokens/fobs to above user 20? easier to know who has what fob for deletion/renewal no matter which system, less risk of knocking out a valid code or fob. user 1 = 21 fob husband admin (but set to normal user) user 2 = 22 fob wife user 10 = 20 Cleaner and so on? If you think education is difficult, try being stupid!!!!
james.wilson Posted May 19, 2013 Posted May 19, 2013 Yes but only on panels that cant support prox and code correctly securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
