alterEGO Posted May 19, 2013 Posted May 19, 2013 seems peculiar, i'm curious what advantage it serves (over straight enrolment to both panels) other than having users in the same user slot on each? then if its lost admin has to also know about using this option. That is not an option on texe, the panel writes to the fob if you use it as standard, unlike the Risco stuff and most other panels that take the fobs number. So if you write the fob on site one you must then import it on any other site, if you don't it will be over written and no longer work at the origional site.
MrHappy Posted May 19, 2013 Posted May 19, 2013 if you don't it will be over written and no longer work at the origional site. danger is should they DIY a premier at home & add there tag, then they can't unset the alarm at work on monday morning Mr Veritas God
Cubit Posted May 19, 2013 Posted May 19, 2013 danger is should they DIY a premier at home & add there tag, then they can't unset the alarm at work on monday morning. Indeed. Just can't see the point of it other than percived market protection.
alterEGO Posted May 19, 2013 Posted May 19, 2013 danger is should they DIY a premier at home & add there tag, then they can't unset the alarm at work on monday morning True but its difficult to account for idiots. Its much more secure in general though. Indeed. Just can't see the point of it other than percived market protection. I think there is some use though. On many of the others the fobs couold be compromised before they are even sold to the user. Just noticed its public so I will leave it there.
arfur mo Posted May 19, 2013 Posted May 19, 2013 Thanks alter, info much appreciated If you think education is difficult, try being stupid!!!!
ruraldev Posted May 19, 2013 Author Posted May 19, 2013 Thanks very much for all the info. Import worked perfectly. Thanks Gordon
