Guest IM_Alarms
Three drinks in one post ! .............. careful now, you might get that late night call out. :D:D:D
  • 2 months later...
The prem 48s a lot better but the 24 does the job.
Weve fitted a few hundred and if there going to fail they do it on first power up otherwise they work and work well
texecom have even put little leds bewhind all the fuses that light up when a fuse blows ( cute ahh )
all in all good bits of kit..
and that s from a long term galaxy fan
The prem is the better pannel
22344[/snapback]
Sep 2nd, eh?
You must be very busy installing those premiers!
Happy Birthday. anyway :)
:birthday:
If you don't know......ask.
  • 10 years later...
I've fitted a Premier 48 and it is the best alarm I have ever used. I am not an installer but it's in my home and is excellent. Don't know much about the galaxy but these are some things that the TeX can do(don't know about the galaxy)
*X10 light and appliance control
*IP module for Wintex and the 3 different iOS and Android apps.
*8XPW and 32XPW to add 8/32 extra wireless zones to the alarm
The metal keypads do look awesome but not used any.
If i ever were an alarm installer, I would use the Texecom as my standard panel.
Also, I'd recommend the 48 over the 24 as it has Double Pole zonme connections.
