Global Tampers
A simple trick i use
so you have global tampers, keeps triggering, these days rare for lace wiring etc. so unless cable damage its likely going o be a lid contact.
1st record each individual s/p loop resistance, look for any obviously high or greatly different resistances, now stick the pair in series with the sab hold off
you can now hear exactly when and if the loop is affected as tamper contacts 'pop' when you lift lids, and know when they remake, and not cluttered by your meter, you have both hands free.
now re-check the loops and look for any changes against earlier measurements.
if you have an open loop but unmarked cables and zones, connect the open pair between negative and bell ring, once you close the loop the siren will sound.
fairly useful arf.
Never thought of the hold off thing I must admit.
Have used the act checkmate in a similar way but the hold off will have a slight delay which may mask some faults
But think if the fun you could have, especially if using master blasters.
I'm sure that the client would understand using a meter would simply be not so much fun.
Plus messing about with another aspect of the system that WAS working before you played with it.
No ta, use a decent meter.
Hey, how about a battery, a bulb and a buzzer????
i'd think a certain amount discretion is called for lol!
fairly useful arf.
the meter before and after comparison test is for tracing intermittent's, sometimes micro switches click but don't make, or at least decent electrical contact, perhaps get knocked. this us just a fast method if finding it without opening j/b's
tamper micro's are rarely moved to clean the contacts inside, so one that is h/r will often alter resistance considerably either up or down having been operated.
do you think after 45 years i can!t break and make competent sound connections every single time - are you having a laugh?
good tip that.
Went to an old keyswitch bently the other week, second visit, my first time on site. Since the first visit it had dropped tampers a few times again
So did the basics, bell tamp good return, spilt the tampers had a reasonable range when split for a 20 year old system. So banged them back together, dug out the crock clips for the meter, then traced the cables. Found few jb's along the way, good tap, still buzzing, then found one on top of a kitchen unit.(lol) Tap, Bingo! Quite like old school faulting, nice satisfaction when you find it
I'll remember that SAB trick, gets a bit tricky to hear the meter on a big site! :)
