Global Tampers
i always make sure its fixed ;).
joking aside - no, but your are getting there though you need to test the various lid tamper adjustments as well for changes in resistance that indicate either you have cleaned the problem contact or it has degenerated. using the panels tamper feature it won't reset (unless you go back to the panel), so a less useful option.
remove any lid siren ceases, close lid siren sounds, using slow actions you ill know its adjustment precisely, if ok move onto next one (quickly if coarse ;) ).
Or just fit a new one.
Again you have no overheads do you.
No maint charges.
Free visits.
Zzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Well if it was to do with what we do and were not condescended to then maybe.
Lid tampers, ffs we use decent stuff now and if an intermittent is suspect we change. ( Also see CHARGE).
Not spend a few hours drinking tea (Soz Gus lol).
Ignoring the previous drivel.
and replace it with your own worse ill informed brand if sh1te?
Use another method, like suggested above, If it is a legacy falling apart last thing you want to do is disturb more items.
OMG! the forum clown utters - why ffsks the LAST thing? its near always the FIRST thing your looking for man. Why in earth would you go looking in j/bs and detectors if obvious faults plainly in front if you are not dealt with first?
after all, your only supposed to be a bloody service engineer, not tea drinking heroic welding exploits telling in general - your job IS to find not only the fault you were called out for, but also look for, detect and prevent as many potential faults as you possibly can while you there, this so you or anyone else including the Police and client is not further inconvenienced - and your boss don't pay twice.
a big clue is in the first word the acronym 'P'MV.
And fit a graded correctly tampered JB, not a leaf spring type if unsure. Job done.
Not mess about for more time than it is worth.
more time than its WORTH! you in a hurry to go welding? come on then 'billy balls', this is a universal tamper, so you trace to a pir - your 'cure' is to replace a pir with a graded/non-graded j/b? (with leaf for micro switch type of course folks)
You forget Arf does not charge for this. Or have overheads, Hence he can afford to potter about for a few hours.
on my jobs thats very true i don't charge unless damaged - but then it don't happen on my jobs thats in part WHY i have few overheads, not a good advert for you now though is it? you obviously need some retraining - as a circus clown come to mind?
if you can't dare to disturb wiring or even move it for fear of causing already faulty connections to go further faulty - and your ethos is to leave them and hope for the best, i have to ask why the hell are you even in this game? the sheer stupidity of your remarks is exposing your total lack of any real alarm knowledge, or seemingly any care for it.
fyi - you will rarely know what exactly has been moved and put back in the past, possibly incorrectly on previous visits by engineers (or even the clients interfering). thats why experienced trained service engineers thoroughly check for and often remake any, even slightly suss connections, and test tamper switch adjustments, its part of being professional, simply don't trust anyone else but ourselves with our reputation, and thats especially to make connections correctly.
you should have learnt that from your dad in your gardens potting shed.
what an utter jack ass!
its not to do with the quality, its ti do with properly tracing faulty or badly adjusted tampers, and diagnosing intermittent contacts
seems you will never grasp that!
Cmon lads time to ignore if you cant
i started this thread with an intended helpful thread, hard to put ignore idiots commenting in your own threads!
Oh god almighty! Carry on Arf.
i will - many thanks
can we be in first name terms - just call God in future (as almighty sounds a bit pretentious ;) )
so i will - many thanks
Wow, you took time there with the spelling too.
For the first few words anyway.
Why it takes time to reply, trying to understand you.
Going to add any more before this reply?
I trace  faults, not **** around all day.
You as per usual bite at anything said.
Give me one of your jobs you know inside out and put a fault on it,
I`ll chase that down before you can go and look in the mirror and preen like a peacock.
FYI once I know a site I WILL know changes made. Your too old and senile now to remember obviously.
Learning new sites now obviously.
Even today, gave a mate details of a job we had done in 2009 when he rang me. Know where all the ........why am I explaining myself to a has been?
As for my dad, he`s dead from a nasty disease. Not from plants as we never had a potting shed.
I could throw in some obvious parental defects, but I find it to be insulting to involve others parents in a discussion nay argument.
Typical Essex mentality.
You sad, sad old has been.
