Global Tampers
I get what you are saying Arf but I think it would annoy the hell out of the neighbors. and the custome alike, not only that it actually promotes that the sounder is ignored  not sure its something I would want my blokes using
and thats perfectly fine,
i generally work alone, just a handy trick but not used every week.
currently working on a large commercial no zone list, markings on few cables using biro - but unreadable, and on an industrial estate, no prob's with neighbours, and give's the sirens a good work out :).
must be 30 or so doors, all listed as "DOOR IN WAREHOUSE" on the TS.2500, only 9 warehouses to choose from :( so i have ti check each one marking cables as i go, very easy to duplicate and overlook one if not paying attention.
another option if looking for a zone that is setting but no idea where it is, hidden behind stock what ever, use an output to follow that zone, trigger a pmr from the output with roger bleep enabled, as soon as it actions you get a remote signal on the 2nd pmr.
That is a surprise. and  I bet you use it all the time.
Fair enough, but making them pointless.
Thought you sorted this at the first attempt?
Or do a correct walk and tamper test in the first place.
You give out such advise, that no doubt works. But takes time. We find the fault, not take a week drinking tea.
How can you ignore this Arf as he gives comedy value to this site?
so at least i'm of some value then?
yes, just imagine how much effort would be needed to replace your random ramblings & typeo's with automatic program ?
So long as I read all your posts in the voice of count arthur strong even I can put up with you
