Vini Posted May 23, 2013 Posted May 23, 2013 Hey all, just in the process of rejigging the alarm, and it's been a while since I've tinkered with the wired stuff... I want to switch a single PIR for a Shock on my G2-20... Forgetting the 'quality' of the wiring, how would this transplant over to the Viper? And resister location?? Thanks in advance! Quote
Lwillis Posted May 23, 2013 Posted May 23, 2013 1k across tamper, From one side of tamper into 1 side of alarm Out of empty alarm back to panel Aux + Aux- Is the shock self resetting? The older ones wernt. And used to have to fit a normally closed push button on the panel to drop the power for a second for it to reset. Quote
Vini Posted May 23, 2013 Author Posted May 23, 2013 Like this CP.JPG Excuse the CAD drawing My hero Is the shock self resetting? The older ones wernt. And used to have to fit a normally closed push button on the panel to drop the power for a second for it to reset. It's a brand new Viper GLX, I don't understand the above, but am assuming I don't need to do anything funky? Quote
Lwillis Posted May 23, 2013 Posted May 23, 2013 Just released what I wrote was a load of ********. Sod it off to bed. Quote
Oxo Posted May 23, 2013 Posted May 23, 2013 Just released what I wrote was a load of ********. Sod it off to bed. LOL Awwwwwwwwwwwww Busy day? Quote
arfur mo Posted May 23, 2013 Posted May 23, 2013 you need to reduce those bare wires, cut them down so casing nearly meets the connector block. be careful the resistors in the picture don't short out due to bare resistor leads and your exposed cable ends, which can happen as you close the lid. nice touch is to use some sleeve casing stripped from larger size surplus cable, and put it over the resistor leads. Just released what I wrote was a load of ********. Sod it off to bed. just as well you 'released' it the . Quote If you think education is difficult, try being stupid!!!!
Lwillis Posted May 23, 2013 Posted May 23, 2013 LOL Awwwwwwwwwwwww Busy day? Call out at 3am , non stop all day since, finished at 6. And then had to take to toilet to bits to see why it's not flushing. Best day ever. Quote
antinode Posted May 23, 2013 Posted May 23, 2013 Like this CP.JPG Excuse the CAD drawing Correct me if I'm wrong, but I'm sure last time I fitted an EV-105, the neg is on the outside with the pos next to it (the link is the negative control line for the LED) Call out at 3am , non stop all day since, finished at 6 No rest time? Quote Trade Member
