Finally got round to sorting this tonight, during testing all was well. But since it has triggered, the LED has not stopped flashing.
Arming/Disarming has not helped.
Anyway to sort/reset this?
You need to drop the power to it for a few seconds before setting, we used to fit a n/c button on the bottom of the panel or adj the rkp.
Is that drop power to the GLX, or panel?
Bit of a pain really - can I disable the LED totally, given its location it would be fairly obvious if that was the PoE? :(
Change the output of the panel to detector reset. Then connect the 0v of your viper to it. This will power cycle the unit every time you set the alarm, thus clearing the led.
In the book of words :)
Change the output of the panel to detector reset. Then connect the 0v of your viper to it. This will power cycle the unit every time you set the alarm, thus clearing the led.In the book of words :)
Indeed. Rtfm
Posted (edited)
I've read the book of words and it's got me confused...
My outputs;
1001 Set
1002 SPK Driver
1003 Bell
1004 Strobe
0001 Fire
0002 Panic
0003 Intruder
0004 Assist
0005 Omit
0006 Fault
0007 Confirm
0008 Tamper
Is it simply a case of changing 0003 Intruder to DetRst? Would that change all my Zones set to Intruder to DetRst, and if so, is that a problem?
I'm guessing I cannot set a specific zone to a specific output via RKP.
Looking at the wiring within the panel, I am able to identify the Viper, however, cannot see how changing the wiring in there would help.
Help?  :turtle:
Edited by Vini
The 000x outputs are off the comm trigger lead so you cant use them, it will have to be one of the 100x outputs your currently not using
So I can change 0001 from Fire to DetRst, but I'm not sure how link that specifically to what is Zone 1004 in this case...
I am not entirely sure which Zone 1004 is in the panel...
Do I even need to be in the panel!?!?
