James Vincent Posted July 25, 2017 Posted July 25, 2017 (edited) 4 minutes ago, al-yeti said: So back to where you started I'm now fully operational, minus the sensor over the replaced window. I'm assuming the window fitter has screwed the cable... Tomorrow, I'm going to reconnect 1004 to the panel, and replace the resistors and connections at the sensor end. If that causes the same issue, I'll conclude the wiring is knackered and replace with an RF sensor. 2 questions. - Can you disable the Keypad keytone? - Is there a mode to put the panel in to avoid the sirens going off when "playing"? Edited July 25, 2017 by James Vincent Quote
