Minerva Mxc Fire Panel
Hello there
I maintain the fire systems within a very large facility. In one of the buildings we have a Minerva MXC fire panel (The type with the plactic case) Unfortunatly the panel enable key has broken the plastic switch. This means that the only way to reset the system after an alarm is to down power the panel.
Ive heard that there is a way of enabling the keypad, with a number of key presses, is this correct? If so would anybody be able to send me the sequence?
We are hoping to replace the panel with a newer model with the metal casing to ensure this does not happen again, but due to the time it takes to complete change control procedures, we need a way of access the old panel until the new panel is installed.
Regards
Dan
Those 3 grey buttons are the code ones,mark them 123 then type 12321 that enables the panel
ok thats fine then.
Thanks alot for your help! ill go and try it out in a bit.
One other question, seeing as your online and the admin doesnt appear to be. What qualifications do you need to show to get into the trade forum?
cheers
