Pyronix Euro Mini
sound panels, use them for the small jobs
as above, good little panel but with a couple of daft niggles, but customers like them and find them easy to use.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
It doesnt, technically has a lot more
  • 3 months later...
Not the norm. you can put multi detectors on one zone but always try to use the formula 1 detector 1 zone, if you want to use multi detectors on one zone use the in line resistors in each detector then the last detector use an eol.
They are not bad panels, pretty straight forward really.  On a Euro panel all the -ve's are common, Its not good practice but if cabling for extra devices is an issue then it is possible to get 4 devices on 1 6core cable. Red = +ve, black = -ve, use each other colour as a zone wire and take a -ve from the power -ve to the tamper terminal. Again its NOT good practice but can get you out of a sticky situation.
