Intellisense 800L
reg10
your sounder could  be dragging the panel down. But yes you can test at the panel just meter between hold off pos and bell neg
Problem solved, replaced sounder unit as was dragging panel down.
Thanks for the advice.
As for the rest of the comments, can I suggest you go and get a life.
Your forum is all the poorer for your pathetic comments.
Glad you sorted your problem, Id suggest you lighten up a little. x
  • 3 weeks later...
Hi Richard, only keypads AFAIK, these are becoming very rare. What do you need?
I need a circuit board.  The bell-box outputs are staying high when the alarm is triggered.  This happens whether the box is connected or not.  Linking the bell-box trigger of 0V sets it off though.
Time to change I think, look at the Texecom range.
