Jeeva Posted July 22, 2013 Posted July 22, 2013 Hi There - I was looking for the contact for Dale who has offered a wiring diagram on the Rokonet PIR - I see he has already assisted some one with the wiring. The PIR has the following: 2 x alarm inputs, 2 x tamper inputs and a negative and positive input. The brochure does not at all state how this must be wired. It also has an input for a jumper near the leds. Please assist. Much appreciated. Jeeva *edit jpw
arfur mo Posted July 23, 2013 Posted July 23, 2013 be nice ti know which Risco detectir model . but generally in most makes -: Positive will + Negative will be - tamper is a simple switch circuit through the ld and in some rear contacts. the alarm 'pair' normally denoted as C & NC, are a simple circuit closed through the Detectors relay, will show lo ohms when powered and detector not detecting, connected to a zone 'pair'. drawing in box should show ths. If you think education is difficult, try being stupid!!!!
