Monteey Posted April 15, 2006 Posted April 15, 2006 The 6210 fiddle involves purchasing a nokia 6210 off ebay, then a payt sim to your chosen network, then you'll need a uni-com lead from Texecom to connect it all up, panel sees it as a gsm module, saves a fortune on the cost of the texecom gsm module Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest James Heath Posted April 20, 2006 Posted April 20, 2006 The 6210 fiddle involves purchasing a nokia 6210 off ebay, then a payt sim to your chosen network, then you'll need a uni-com lead from Texecom to connect it all up, panel sees it as a gsm module, saves a fortune on the cost of the texecom gsm module Neat! I'll get on with that then - where do I find the wiring details? I'm also after hooking up the panel to a PC I have running all the time, to log & possibly program via wintex - if I'm doing this in serial, can i make the cable myself? , J
breff Posted April 20, 2006 Posted April 20, 2006 Id like some details on that as well Mont. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
sparky83 Posted April 20, 2006 Posted April 20, 2006 sounds interesting, me 2 if its not too much hassle! Trade Member
martlewis Posted May 30, 2006 Posted May 30, 2006 So only 1 concern, don't payt sims get disconnected if not used for long periods? I would hope my alarm won't be activated by anyone!!!
