Galaxy G2-44+
Hi Guys, I am trying to workout the best way to trigger a old Pyronix Vocaliser with a G2-44+, the vocaliser requires seperate Negs applied for intruder, fire and PA but I only need the intruder signal. Can I do it from the on board relay or will I have to use the trigger header terminals? Be gentle with me I'm a Fire alarm engineer, but promised to help a mate sort out his alarm
if you're not sure, bang it off the bell trigger.
the switched output is a better idea though, but it will require programming,
