Sterling 10 panel
Guest farrellcom
Guest farrellcom
Can anyone help me with my first alarm fit? I have a pyronix sterling 10 panel and want to fit an internal sounder "Lynteck sound bomb" reading through the panel fitting instructions I cannot see were to wire the internal siren which only has 2 wires one red one black. help.
Guest farrellcom
Red to bell +
Black to bell -
22593[/snapback]
Thanks.
Obvious I surpose, you must think im stupid.
Was under the impresion for some reson you could have one sound without the other I must be wrong.
Thanks mate.
you're internal speaker terminates to " +SPKR - "
you're external SAB (bell box) terminates to " B+ B- STB BA BT "
that way they will work independantly as you thought
If you don't know......ask.
Guest farrellcom
22598[/snapback]
So I can put the internal sounder together with the internal speaker? thats ok is it?
Red to bell +
Black to bell -
22598[/snapback]
I could be wrong here (and am ready to be corrected as I have not installed the Stirling 10 before), but surely is the soundbomb is connected to Bell + and Bell - you will get a constant output from the soundbomb? I would have thought it correct to connect to Bell + and Bell Activation (BA)?
Or am I missing something obvious?
D7
sorry, thought we were talking about internal speaker (16 ohm).
The sound bomb should be connected to B+ and BA as Deltaseven pointed out
Guest farrellcom
Yep, D7 will be right then. I didnt realise pyronix used different descriptions for their bell connections.
:huh:  we got there in the end!
22609[/snapback]
Thanks eveyone for your advice if i heed anymore help i know were to come
