Karizma Plus
Guest mike2004
Guest mike2004
Hello,
Considering buying a Karizma Plus panel for a installing as a relatively competent DIYer / wannabe sparky!
Is this system ok? Are those ID "biscuits"(!?) reliable?
Would I be better with a Texecom panel?
Many thanks,
Mike
Guest mike2004
Thank you for those replies.
I can't forsee any nearby major sources of interference, but it does sound like from what you're saying that if I want to maximise the reliability of the system then I should probably go for complete conventional wiring rather than the iD system.
Is the Karizma Plus panel itself reliable? How does it compare to Galaxy 16?
Thanks,
Mike
go galaxy every time...tho if you really want to play,,go for the g18 if £££ allow..
NOTHING compares to Galaxy.
The most flexible panel i've ever used...
But it's ££££
:D:D
Yeah, I'm sure the guy who designed the lid used to do the puzzles on the Krypton factor.
Regards
Bellman
I've got it down to a fine art,
It took some time to get the "technique" right though :P
Regards
Bellman
Regards
Bellman
22714[/snapback]
It's all in the wrist movement you know!
Perhaps that's why we are called a bunch of ******* here!
