Ctaylor Posted August 4, 2013 Posted August 4, 2013 Hi I Installed my own texecom last year with the the help of this forum. Today whilst decorating I had to take down one of the pir in the living I entered and enabled engineer turned power of and took it down. The alarm went of so I put the code in. But now it won't let me reset the tamper fault. Banging head against brick wall can anyone help
matthew.brough Posted August 4, 2013 Posted August 4, 2013 Hi I Installed my own texecom last year with the the help of this forum. Today whilst decorating I had to take down one of the pir in the living I entered and enabled engineer turned power of and took it down. The alarm went of so I put the code in. But now it won't let me reset the tamper fault. Banging head against brick wall can anyone help Tamper fault still present? I'd check that you put the pir back properly and the tamper is closed. www.securitywarehouse.co.uk/catalog/
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 No I checked zone status and it said that zone was secure?? Am I resetting it wrong. I usually enter code press reset and its done
PSE Posted August 4, 2013 Posted August 4, 2013 If you have put the PIR back together properly, its probably programmed for engineer reset on tamper  Try entering the eng code & reset
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 I'm not sure how to do this. If I remember is this in the control pannel
Rulland Posted August 4, 2013 Posted August 4, 2013 When you installed it you must have set up/used an engineer code for programming etc, use that code to try and reset the system.
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 When I use my master code it has the option for enabling engineer. I thought I set my master code for engineer utilities??
Rulland Posted August 4, 2013 Posted August 4, 2013 Enabling engineer just allows an engineer access using the engineer code, you would still need a valid engineer code to reset faults that require the engineer code.
