sjsturner Posted August 4, 2013 Posted August 4, 2013 In that case eng code is probably still the default code
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 My head is battered. It not the default I tried that. I need to remember what I changed it to. Or I'm gonna have to default it at the control and re program really don't wont to do that. What's makes it worse is I use 6 digits arrrr
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 Just ask it would come up when putting it the control panel? I don't need to put master in first then that one?
PSE Posted August 4, 2013 Posted August 4, 2013 You can default just the eng code on it, no need to default the whole panel. That is unless you managed to code lock it without knowing
Rulland Posted August 4, 2013 Posted August 4, 2013 If you mean allow engineer access then enter engineer code, yes. If you've locked engineer code in your initial programming then you've got a problem.
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 I'm sure I set it up so the master can change the engineer code is this possible?
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 Ok I've got he instructions to reset the code. How do I actually short out the pins. And be still powered does that mean mains? Ps thanks for your help so far
Ctaylor Posted August 4, 2013 Author Posted August 4, 2013 In fact I sure my default pin is a button. Will be ok putting the bells in hold off. For when I do this?
