How To Test Intruder Alarm
Crussell87
  On 11/08/2013 at 08:12, steveo44 said:
Does the battery have to be fully charged for this reading?
Should be ok as long as it has enough power to hold the panel up otherwise you will not get stable reading
as long as the battery is not heavily discharged or shorting internally, it will have no real effect other than to smooth 12 volt rail ripple (new panel this should not be a problem). tbh if not sure especially if older battery to best disconnect it for this test.
you should also test the charging volts from the panel ideally (for most makes) @13.65, again do this with battery disconnected as a low battery will draw down the voltage reading affecting accuracy, as having it in circuit will not give you the maximum charging voltage the panel psu is capable of delivering, and it may actually be over the recommended voltage when charging, leading to earlier failure of battery.
personally if bellow 13.3 i consider as under charging will occur, making the battery less capable of its true standby time potential, over 13.8 overcharging and heating up of the battery will occur, reducing its expected service life 3 - 5 years considerably.
I haven't particularly followed the rest of this thread, and have no idea if other panels do this too, but the PSU output of the 9651 has been seen by me producing a rather nasty 1Hz momentary spike if run with the battery disconnected. This can be heard a mile off if you're using Pyronix Twin Alerts as I used to (but no longer... just like the 9651)
not into that panel, wonder if it is to do with controls internal battery testing?
i remember the 9100 and iirc the 9800 internal speaker used to click with the ewb strobe operated in alarm
Just do what Aunty do at a School I am in the process of taking over,
Stand by keypad for 25 mins, sign off job sheet, go to next.
Only about 64 zones.
No tampers on SAB, Redcare Rio.
That is to start with. Not looked any deeper yet...................
£650 PA for maint.
W anthings
Oh yeah, they cannot work out how to interface the fire alarm module into the mag locks.
Cannot get a handset to work on the system (Videx).
Going to  be so sweet taking this one away and sorting it out. The premises manager loves us to bits anyway.
Now to really impress.
There's a gold in Staffordshire who do the same. Council contracts. Battery checks and replacements? Don't be silly.
  On 11/08/2013 at 11:52, Cubit said:
There's a good in Staffordshire who do the same. Council contracts. Battery checks and replacements? Don't be silly.
Maybe an opportunity for cubit alarms?
well, as your so keen to wear that badge of gold, perhaps it says much for your standards.
They are making a new colour just to reflect our standard of work called platinum.
