opitma xl6
Guest keithh1
Guest keithh1
hi all new to this would like to know if any one has any instructions for opitma xl6 alarm :)
Guest keithh1
The XM is the same as an xl (more or less)
Pete :)
22634[/snapback]
thanks for your reply is there away you canturn the volume down on the panel :)
Guest keithh1
thanks for information do you know if you can turn the volume down on the pannel :)
Guest Peter James
Yes there is a vr on the pcb your installation company will be able to do this for you.
Pete
  • 4 weeks later...
Guest obrienk
Pete
22645[/snapback]
hi,
i can't seem to the link above to work :wacko: could someone email me the pdf file?
cheers, kieran :)
Guest obrienk
This is the XM4 , same as , but 4 zones.
^_^
26199[/snapback]
thanks keith! :)
