Park Posted August 16, 2013 Posted August 16, 2013 4. Aug 16, 2013 9:22 AM (in response to hacman) Re: Chubb Sentinel CA67 alarm panel Hi, I have I believe rebadged Guardal Rascal Super & ACTIVE5 to Chubb Sentinel CA67 integrated single panel system but HAVE NO UC. The mains & Day only LEDs are ON. I also have bought the user, engineer manual and HAVE the EC. The system is in Quiescent mode. PIR detect ok. I do not want to trig alarm but if it does how can silence it (Internal or External) using the EC ? Is it possible to: 1. Just to test the EC code only without opening the panel and since no change just # to EXIT Eng mode ? OR HOW TO use tamper cct to timeOUT itself ? 2. How do I differentiate between accept and reject bleep ? 3. If EC code is OK then can I use it to assign new UC only, 4. If there is no other option and have to use the link I can see it in diag (BUT IF I find it inside) Where is the MEM DEF LINK to short it, reset the UC to 1234 assume the programs are not affected. Thanks. Park, London.
PeterJames Posted August 16, 2013 Posted August 16, 2013 That panel is at least 15 years old I would be looking to replace it if I were you. Not sure what your asking on question one The reject beep is two sad sounding beeps dee daa and the accept beep is a cheerful di di da Nope no idea what your asking what does EC mean? What does UC mean? Again I havent a clues what you are asking on q 4
matthew.brough Posted August 16, 2013 Posted August 16, 2013 I struggled. Engineer code, user code? www.securitywarehouse.co.uk/catalog/
