Guest sanderson Posted September 7, 2004 Posted September 7, 2004 Hi I moved in to my house recently with an Accenta 8 alarm system installed, as I am new to this I was wondering if someone could help me I had to do some decorating in my living room, which required me to take down one of the zones (3), I unwired the device, taking a note of the order of wires. When I re-wired the zone I noticed that the infrared sensors from any of the zones no longer came on - I have a total of 3 infrared zones. I then tried to arm the system, on the RKP all the zones were lit with a continous bleeping noise. I have double checked the wiring and it seems ok. Thanks in advance.
Guest Posted September 7, 2004 Posted September 7, 2004 HiI moved in to my house recently with an Accenta 8 alarm system installed, as I am new to this I was wondering if someone could help me I had to do some decorating in my living room, which required me to take down one of the zones (3), I unwired the device, taking a note of the order of wires. When I re-wired the zone I noticed that the infrared sensors from any of the zones no longer came on - I have a total of 3 infrared zones. I then tried to arm the system, on the RKP all the zones were lit with a continous bleeping noise. I have double checked the wiring and it seems ok. Thanks in advance. 22667[/snapback] fuse
Guest sanderson Posted September 7, 2004 Posted September 7, 2004 A silly question. How I would I know what fuse has blown - I have a diagram of the PCB and there are three: 1A 13v & Speaker 1A Bell & Strobe 1.6A Battery Can I do this whilst there is power to the board. Thanks for such a fast reply.. Regards
Guest sanderson Posted September 7, 2004 Posted September 7, 2004 I dont have anyone who looks after the system - is this advisable then. As with the blown fuse - could this of been caused by a short - the cables were not covered whilst I was decorating.
Guest Posted September 7, 2004 Posted September 7, 2004 I dont have anyone who looks after the system - is this advisable then.As with the blown fuse - could this of been caused by a short - the cables were not covered whilst I was decorating. 22675[/snapback] def' meter the fuses & replace
Guest sanderson Posted September 8, 2004 Posted September 8, 2004 Thanks for this - I will try this. Do you know how much it usually costs for an engineer to visit onsite to test/fix the alarm system, also do you have any idea of any reputable companies that do this. Regards
Guest RICHL Posted September 8, 2004 Posted September 8, 2004 usually £45.00 upwards depending where you are and if anything else needs to be done. where abouts are you? Most installers wont touch a one off job but will take on an exsting install for annual inspection as long as it is a decent quality install.
Guest sanderson Posted September 8, 2004 Posted September 8, 2004 I am based in Kent, Bexleyheath (DA7) Regards
Guest RICHL Posted September 8, 2004 Posted September 8, 2004 Kent?! sssssshhhhhhhh [sharp intake of breath] it'll cost you! I'm sure someone on here will be not too far away, if not try Yell.com
