Flash Upgrade Galaxy G2 Panel
dwdave
Probably not the usual DIY installer question but here goes ....
Ive got a galaxy G2 panel which is pretty old and Im looking into fitting the SelfMon Ethernet Module I found via the forum.
How can I get hold of a newer firmware version and is flashing the system possible ?
Thank you.
'till the next question ...
I think it would be cheaper to buy another g2 board with latest firmware. Any reason you want to upgrade it?
As I was looking to add the SelfMon ethernet/Rasberry Pi module and it requires a higher firmware version than the one I think I have got.
Ive just fired the panel up and hooked on an RKP and it says
Galaxy 500 V2.16
Time             Date
Am I right to assume that I have Firmware V2.16  ??
Thats not a G2, thats a galaxy classic. A very different animal to the G2. Correct you have v2.16 so I assume you have had that panel a long while.
This will probably be an EPROM chip that needs replaced to upgrade the firmware. I have the latest EPROM's for the older Galaxy 18 and 60, but I'd have to dig through boxes of old panels to see if I have a newer 500 panel firmware.
