Noullis Posted August 24, 2013 Posted August 24, 2013 Hi I bought Texecom Premier Elite 24 Panel with Texecom PIRS. I am using 6 cores cable. I used two for a/c, two for alarm and two for the tamper. I connect each two alarm cables to each zone and the two tamper cables on AUX Tamper on the panel with serial way. On Zone settings i set on Double Pole/EOL but i have for all zones Tamper Alert. Walk Test show only *NONE*. I can see the RED Led on Pirs but my alarm system is not recognize PIRS. If I change the settings on Close Circuit i don't have tamper for each zone but again the walk test is not working. Please Help me
matthew.brough Posted August 24, 2013 Posted August 24, 2013 The 24 should just be wired with resistors making you only need 4 wires. 2 for power and 2 for the alarm and tamper www.securitywarehouse.co.uk/catalog/
Noullis Posted August 24, 2013 Author Posted August 24, 2013 So you that i have to use resistors? I have to connect the left alarm (pir) on the left zone (panel) and the right tamper(pir) to the right zone(panel)???? like the picture???? Uploaded with ImageShack.us
matthew.brough Posted August 24, 2013 Posted August 24, 2013 That's right. What model of pir are you using? www.securitywarehouse.co.uk/catalog/
Noullis Posted August 24, 2013 Author Posted August 24, 2013 I am using this one Texecom Premier Compact QD Quad Element PIR so and resistors how have i to connect them? like this? Uploaded with ImageShack.us Is there any easier way?
matthew.brough Posted August 24, 2013 Posted August 24, 2013 Middle picture Just a thought. Does the instructions that came with the pir say it has inbuilt resistors? If so that will make life easy for you. www.securitywarehouse.co.uk/catalog/
Noullis Posted August 24, 2013 Author Posted August 24, 2013 If i have two pirs on one zone the first picture right? How can i understand the resistors? On the panel there are two types but they don't write anything to understand the types..... I believe yes, check the pictures please If pirs have already the resistors have i get out the two other cables????
sixwheeledbeast Posted August 24, 2013 Posted August 24, 2013 If i have two pirs on one zone the first picture right? How can i understand the resistors? On the panel there are two types but they don't write anything to understand the types..... One device, one zone; with very few exceptions. https://en.wikipedia.org/wiki/Electronic_color_code
james.wilson Posted August 25, 2013 Posted August 25, 2013 You shouldn't put more than one device on a circuit securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
